Old 03-09-2021, 02:59 AM   #13
Originally Posted by KenTaoyan View Post
Filling the oil up halfway on the site glass then I started the engine and I couldn't see the oil in the site glass. I know the oil gets distributed around the engine. (Upper and Lower) what is the procedure for the oil change? Start it up and let it circulate or just leave it at that? Still a newbie and about to do the full meal deal to get ready for spring.
Otherwise, these engines are supposed to have about 1.1 quarts in them, and most people just put 1 quart in and that tends to put the oil in the sight glass about halfway. While running it is normal not to see the oil in the sight glass as the engine is circulating a portion of said oil.
The typical method for checking the oil level on many Honda engines is to run the bike for a couple-few minutes, shut it off, and let it sit for about 5 minutes and then check the sight glass level, and if needed top it off a bit.
